(08.07.2022, 00:53)hoeberlin schrieb: Hi, Victor,
normally there schould be no Problem with this.
No luck
The connection at the moment is the next:
- Röhrenverstärker 100V plugged to Trafo 220V>100V Sanyo
- Trafo 220V>100V Sanyo connected to outlet wall; it has a japanese cable with plug without ground but ground connection in the chassis, so chassis of Trafo 100V connected to outlet wall ground (first option) and second option connected as well to metal pipes from the wall (heater). Third option is without any ground from the Trafo chassis.
Then...
- Röhrenvorverstärker RIAA is 220V so is connected in different outlet wall plug than Röhrenverstärker. I tried with ground and without ground from the electric net. Anyway Röhrenvorverstärker RIAA has not Ground connected to the Power Supply Cable: its Ground needs to be connected from its chassis. So is connected to the Röhrenverstärker. I tried direct to another Grounds as well like a test. I mean, both chassis are connected.
- Plattenspieler is 220V and no Ground in Power Supply Cable but is joint with interconnection cable RCA, what is the usual. In addition I did a direct connection from its chassis but no good results. Anyway the Plattenspieler is just no possible to use without its Ground because the noise in this case is even dangerous noisy for the speakers. Is connected in the same trip than Röhrenvorverstärker RIAA.
So all the system is working with just one Ground. I checked that all the Power Supply cables are in the right position Line-Neutral.
I don`t have any other gear connected in the same trip. No switching trafos like mobile chargers or similar. I have a filtered trip to isolate them, but anyway at the moment everything is disconnected. My DAC is with batteries and even a small lamp is with batteries as well, paying attention to not to contaminate with any switching trafos around.
This is a very sensitive equipment, autobias, Röhrenvorverstärker RIAA lift a small signal from 2mV to 2V so could elevate as well whatever another noisy electrical signal around. I have very well protected power supply cables in both amplifiers (RIAA and Power).
So my idea is the loop Grounds interconnected due a lot of another electric gears in an old building, is producing noise. With regular modern gears is not possible to hear.
The technician in Chile say that is not allow to connect some sensitive machines to the electric net if the Ground voltage is over 1V and specially for these kind of equipment is very bad. His recommendation was to make an special dedicated electric line to this outlet wall or to use an Isolation Transformer special for my requirements. This is a rented place so I think much better just the Trafo. I was using it before and in my experience Trafos are absolutly helpful and in this case looks is a must. I think.
Whatever advice to make an audio isolation transformer is very appreciated. Or another advice as well
Victor
